Lightwave plugin - AHK, 3x QuickCut
3x QuickCut - launches 3 different script using the same hotkey
http://youtu.be/82fL42IBVC8
the code >
#IfWinActive Modeler
; Keypress detection for Altx.
x::
if counter >= 0 ; setTimer already started, so we log the keypress instead
counter++
return
counter = 0 ; Start setTimer and set the number of logged keypresses to 0
setTimer, Altx, 750
return
Altx:
setTimer, Altx, off
if counter = 0 ; The key is pressed once
Send, ^+l
if counter = 1 ; The key is pressed twice
Send, ^+m
if counter = 2 ; The key is pressed thrice
Send, ^+n
counter = -1
return
3x QuickSaw - launches 3 different script using the same hotkey
same code as above, just tweaked slightly...
Lightwave plugin - AHK, 3x QuickSaw
http://youtu.be/18EWkbcEous
the code >
; Keypress detection for Altc.
c::
counter++
return
setTimer, Altc, 750
return
Altc:
setTimer, Altc, off
Send, ^+i
Send, ^+j
Send, ^+k
counter = -1
return
3x XYZ - launches 3 different script using the same hotkey
Lightwave plugin - AHK, 3x XYZ
http://youtu.be/qqYbh1q1O2w
the code >
; Keypress detection for Altdim.
v::
counter++
return
setTimer, Altdim, 750
return
Altdim:
setTimer, Altdim, off
Send, ^+x
Send, ^+y
Send, ^+z
counter = -1
return
more...
3x Triple - launches 3 different triple commands using the same hotkey
Lightwave plugin - AHK, 3x Triple
http://youtu.be/_jUdsfLKJR8
the code >
; Keypress detection for AltTriple.
l::
counter++
return
setTimer, AltTriple, 750
return
AltTriple:
setTimer, AltTriple, off
Send, ^+o
Send, ^+p
Send, ^+q
counter = -1
return
Waves of light
Stuck in a very big cube
Well, after playing around with AHK, here's my full code (below). I think this is really going to speed up my modelling workflow, if not just for the select expand, select loop and select connected on the MouseWheel. Thank you once again for bringing this to my attention.
Code:
; DoubleTapC begin.
; Keypress detection for DoubleTapC.
c::
counter++
return
setTimer, DoubleTapC, 750
return
DoubleTapC:
setTimer, DoubleTapC, off
Send, c
Send, +^g
if counter = 2 ; The key is pressed twice
Send, +^h
counter = -1
return
; DoubleTapC ends.
; ChangeKeyD begin.
; Keypress detection for ChangeKeyD.
d::
counter++
return
setTimer, ChangeKeyD, 600
return
ChangeKeyD:
setTimer, ChangeKeyD, off
Send, d
Send, l
Send, +^t
counter = -1
return
; ChangeKeyD ends.
; DoubleTapT begin.
; Keypress detection for DoubleTapT.
t::
counter++
return
setTimer, DoubleTapT, 600
return
DoubleTapT:
setTimer, DoubleTapT, off
Send, t
Send, +^i
Send, +^j
counter = -1
return
; DoubleTapT ends.
; DoubleTapQ begin.
; Keypress detection for DoubleTapQ.
q::
counter++
return
setTimer, DoubleTapQ, 750
return
DoubleTapQ:
setTimer, DoubleTapQ, off
Send, q
Send, +^k
Send, +^l
counter = -1
return
; DoubleTapQ ends.
; DoubleTapV begin.
; Keypress detection for DoubleTapV.
v::
counter++
return
setTimer, DoubleTapV, 750
return
DoubleTapV:
setTimer, DoubleTapV, off
Send, v
Send, +^e
Send, +^f
counter = -1
return
; DoubleTapV ends.
; ChangeKeyB begin.
; Keypress detection for ChangeKeyB.
b::
counter++
return
setTimer, ChangeKeyB, 750
return
ChangeKeyB:
setTimer, ChangeKeyB, off
Send, b
Send, +^q
Send, +^r
counter = -1
return
; ChangeKeyB ends.
; ChangeKey1 begin.
; Keypress detection for ChangeKey1.
1::Send, +^l
; ChangeKey1 ends.
; ChangeKey2 begin.
; Keypress detection for ChangeKey2.
2::
counter++
return
setTimer, ChangeKey2, 750
return
ChangeKey2:
setTimer, ChangeKey2, off
Send, +^b
Send, +^c
Send, +^d
counter = -1
return
; ChangeKey2 ends.
; ChangeKey3 begin.
3::
counter++
return
setTimer, ChangeKey3, 750
return
ChangeKey3:
setTimer, ChangeKey3, off
Send, +^m
Send, +^n
Send, +^p
counter = -1
return
; ChangeKey3 ends.
; ChangeKey4 begin.
4::
counter++
return
setTimer, ChangeKey4, 750
return
ChangeKey4:
setTimer, ChangeKey4, off
Send, +^u
Send, +^v
Send, +^x
counter = -1
return
; ChangeKey4 ends. 4
; MOUSE BUTTON CHANGES.
; BEGIN.
MButton:: Send, {Delete}
WheelUp:: Send, {Up}
WheelDown:: Send, {Down}
+WheelUp:: Send, +]
+WheelDown:: Send, +[
+RButton:: Send, ]
+MButton:: Send, {Right}
^WheelUp:: Send, +^o
^WheelDown:: Send, +^o
; END.
GraphXs
GraphX
That is cool, though where do you set the initial key to modify in the script? For example you are using L for the triple commands, but I don't see i "L" ref in the AHK script? never mind, found it.
Do you know of a way to use this method to have multiple command follow one another? Is that possible?
**** Got it to work!
