Last RManCollect for Mac
dpont
I would like to know if the new MacUB updates of RManCollect,
including the last Texture, Gabor Noise, Simplex Noise, Torch...
for Textures and Nodes, and a nodal version for 2018,
are correct and running as expected,
seems to work for LW 64 bits but not sure for LW 32 bits.
Denis.
jwiede
Electron wrangler
Okay, aside from the Gabor Noise node panel's "About" button not seeming to do anything, thus far it all seems to be working pretty well (UB64 on LW2018.0.7).
I'll slowly finish up with these tests, then move to testing LW2015.3 UB64, and then see if I can easily bring up a 32bit MacOS VM with older OS to test 32-bit behavior over the weekend.
Denis, if you have other nodes you wanted tested for UB64 (and UB32 potentially, but probably should wait till I get that VM working, will let you knw) with LW2018 and prior, either PM me here or plz send me email.
BTW, thanks very much for producing a Mac UB64 version of the RMan collection for LW2018+, it's greatly appreciated!!
dpont
Okay, aside from the Gabor Noise node panel's "About" button not seeming to do anything, thus far it all seems to be working pretty well (UB64 on LW2018.0.7). ...
You should see it near the time line or change the Alert Level in Display settings.
Still interested to know if other 32 bits versions are working,
if someone get it or not, let me know.
Denis.
