Keynote Set
JJTV
Trying to use the Keynote Set and I have discovered an issue that maybe someone here can address. For some reason parts of the white bounding box from VSE are bleeding thru after it is exported to my 460. It appears to be the left side of the box and it is coming thru faintly on the set. I was hoping that the latest update would address the issue but it did not. Anyone else having this problem or perhaps know how to fix it? Thanks in advance.
Jeff
Buddy.Hannon
Do you see it as a faint black line?
You can use the crop tool in the Tricaster and set it to one or two. That should take care of the issue.
