OK thanx to you guys,
I appreciate your help…
Now one after the other
Lightwolf >
OK the line you gave me looks much like
I think I should hit too, I'm gonna try this
right now. According to all I did until now
I guessed it should work with something
like this…
mm… hard to give you immediatly a .bat file,
I'm here on a Mac (for internet) that is not connected to the network so should burn
a CD. However I'll do this if necessary but
let me know what do you need :
- the .bat file when "not working" ? Which is
actually few paths according to Matt's tuto
or
- what is displayed by the .bat file when the
node works (all instructions on rendering process) - in that second case I have to
re-save it with a log file using the way you
gave me yesterday…
Now Matt >
1/ Main Lightwave is installed on HD "C:",
in the directory "Program Files" (default Windows directory) on a machine called "Tour" on the network. I copied on all other machines (nodes) just the "programs" directory of LW, directly on each node, on HD that are also called "C:"
So I have in "Tour" this :
C:\Program Files\Lightwave\[full LW installation, including "config" and "config_sn" folders, as well as sn_init.bat file for the case I
use this machine itself as a node]
And on other machines :
C:\Program Files\lightwave\programs
and also
C:\Program Files\lightwave\sn_init1.bat
2/ Content is on another partition of my HD
on my main machine, called D:
Which gives us :
D:\Content
3/ As I said, my config folders ('config' and 'config_sn') are both located in the folder
"Lightwave" on my main machine.
C:\Program Files\Lightwave\config
and
C\Program Files\Lightwave\config_sn
Of course there are copies of lw3.cfg and
lwext3.cfg in both 'config' and 'config_sn'
directories, as well as I followed exactly
your tip to switch the paths with Layout
shortcuts depending on the working use
or the screamernet rendering use.
4/ The command folder is also in the "Lightwave" folder of my main machine.
Now I must say as long as was making tests
I at the end finished by sharing almost all
my directories of the main machine.
Which means that are shared :
Lightwave directory (as 'lightwave' on the network)
Content directory
config and config_sn directories
command directory
and even the rendering directory where
frames should be written (and which is
located on disk D: of my main machine.
Note : the partition of the disk is made so that
I have a small partition for OS and programs (C)
and a large one for files (Content and renderings).
Nodes are also partitioned disks but
I think these partitions are not concerned,
I at present only used for them the
disks "C" to copy my LW programs directory,
that's all.
