doctorsunshine
it's not easy at all to select and control PTZ, including presets store and recall, from the IP Serie panels ( 2 stripes in my case) .
From the latest user manual :
Press an M/E button (1-8), MAIN, or FOLLOW STRIPE to reset the Joystick to the corresponding operating mode.
To apply a stored camera preset (from 1-8), with the PTZ delegate button lit, hold down the CTRL button and press the numbered (M/E) button corresponding to the preset. To update a camera preset, hold down both SHIFT and CTRL at the same time instead when doing so.
I'm running on TC1 the latest V6 180913 , which is supposed to be compatible with the panel. But it's a big limitation to get only access to the 8 first presets. Hopefully, I'm not running V7 , which is more than ever not an option there.
Does someone have any advice ?
Thanks.
Jerome
Thanks.
Jerome
