Installing DVD Workshop SE
kleima
The African Savannah...
You know, when I first got VT[4] I never installed DVD WSE (either that or I uninstalled it later b/c I didn't like it - I don't remember which). Anyway, now I would like to run a project through it, but I can't figure out where it is, or how to install!? It is not listed in the program list at the begining of the VT install setup.
Pete Draves
The Old Guy
ws
it is found on your 2nd instalation disc.
just run the install program.
you will need the serial number in the inside front cover ov your manual binder
Pete
kleima
Ok, I didn't see it there either, but I'll look again. Does it only show up after I start the installation?
Pete Draves
The Old Guy
ws
if you open the disc it is in a folder named "dvdws"
open the folder and double click setup.exe
if you have only one disc (lw7.5), then it is on disc 1
then cancell out of the toaster install and open the disc.
follow instructions above.
Pete
Pete Draves
The Old Guy
ws
good luck
the program works pretty good
most people are useing tmpenc encoder for quality issues
can be found at pegasys.com
Pete
wvp
Toaster Oven
And you can use DVDWS to encode audio into AC3, even if you want to use another program for the authoring.
