Importing 3dStudio files
creach
Cranky old man
The gent that did our news opens gave us our station logo files as 3DStudio files, *.max I think. We do not have/use that product.
How do I import them into LW express? Or is there a way?
Thanks!
Dan
RomainR
Are we there yet?
In Modeler go to file->load object. Then in the file type just change it to all files.
Choose your max files and you'll get a requester for conversion settings.
creach
Cranky old man
Thanks, Romain.
The File -> Import selection lead me to believe I needed a plugin or something. I'll do that.
Dan
mkiii
Huge Member
To avoid having to do this each time, make sure modeler is not running, open your lwm.cfg file & look for the following line.
''FileType Objects *.lwo;*.obj'' (yours may differ)
Add '';*.3ds'' onto the end, without the quotes, and save.
bloontz
Stuper Member
I don't think you can import .max files can you? At least it didn't work for me... From what I've read you need 3dsMax installed to use a conversion program like Deep Exploration to convert .max files. You can import .3ds files though.
creach
Cranky old man
Well, thanks for the replies...
But it won't import *.max files, as bloontz has said.
Are there any shareware format converters that'll do the job? Or any secret keystroke sequences?
Dan
RomainR
Are we there yet?
Try searching for polytrans. It's not freeware but I think it does the job.
Never used it but have heard of it.
bloontz
Stuper Member
It seems that the .max format isn't public so the conversion applications require Max to be installed to translate .max files, that's my guess anyway. I'm not sure how much would be compatible between .max and .lws, you may be better off having the objects converted to .3ds and rebuild the scene in Lightwave. Perhaps you can find someone with Max who's willing to convert the stuff for you.
creach
Cranky old man
Thanks, gang.
Simply converting them with 3DStudio may not be the preferable choice, but it definitely looks like the most easily accomplished.
Ah, well.
Dan
cgolchert
This space for rent
Nope. it is the only way. Max is the only thing that reads max format unless you have a programmer that reverse engineered Max. But most software license makes that illegal.
3d exploration requres Max to be running to convert files. Most max houses that need to go to game engines have exporters running in max to do that, not a seperate app that converts.
