How to setup an audio mix-minus
PROBLEM DESCRIPTION
User desires control of all audio via an audio mixer outside of the TriCaster.
SOLUTION AND WORKAROUND
Sources that start outside of the TriCaster are routed easily enough to the desired audio mixer, the problem afterward deals with sources generated from within the TriCaster (for example clips on the DDR). In order to make these sources available to an external mixer they will need to be handled through the following method:
  1. Assign all the desired internal audio sources a single group color (for example green, if you are not already using it for something)
  2. Set the group to AUX channel and mute the Master channel. This will keep the audio from going out on Program but will still be active on the AUX.
  3. Now you can route the AUX to your desired Audio Mixer.
