rally1
digitalbuilt
There are two solutions for this somewhat specialized situation. Neither an ideal soultion, but a work around until Newtek are able to add the feature.
1) From the start menu click on Programs, Adobe, Adobe Flash Media Live encoder 3 to start a seperate instance of FME. Hold down the SHIFT button when starting the TC interface from Admin mode, you can then ALT-TAB to FME and record there.
-or-
2) Install Adobe® Flash® Media Development Server 3.5 (Free)
Adobe link (free account required)
Once installed simply push the stream to yourself (127.0.0.1) and use any stream name. See attached.
Upon further testing, the above may not even be needed, you might just be able to type in a dummy URL and stream name and it will work, ie rtsp://192.168.1.1:1935/test
More details upon request. The Dev. server can serve upto 10 clients at a time, so may also be useful for small events or on an internal network. Again it's not ideal as it eats up resources on a machine already starving for more RAM (so my tests seem to show).
-or-
