How to output a Clean Program feed through NDI in 4K
julioac
Hello, I'm using the VMC1 in 4K, therefore the system only allows for MIX1 output only. I need to create an output (only in NDI) that will provide a clean program output, leaving the MIX1 output as the main program.
Is there a way to do that? Is there a way to enable the other MIX outputs only in NDI?
Thank you!
Thank you!
I've tried on TC1. But it couldn't.
The MIX1 output could only be the main program OR the clean program.
There is one MIX output when working in 4K/UHD mode. If you need multiple MIX outputs, then a multi-engine workflow is required.
Is there a workaround to produce an NDI only clean feed output? I have some 4K NC1 I/O outputs available that I could use to output that signal.
Thank you for the response.
Back
