How to load an image sequence?
vncnt
Well-known member
I'm trying to load an image sequence of 950 images with loadimage("path\filename00216000.tif"); and then use it as a background image with SetBackgroundImage(myFile.name);
This works fine for a single image but it fails to load the entire sequence.
I've been searching for a parameter that holds the Image Type.
It seems most parameters in the Image Editor is not very accessible to LScript.
Is there a solution for this?
Sensei
They are not accessible in Python and LWSDK C/C++ as well. You need to cheat by generating fake temporary file on disk, which contains part of .lws or .lwo chunk, and load using LWImageList->sceneLoad()
