How to Install / License LightWave, Turn Off Hub, Isolation Mode, Redirect Configs
Status
Not open for further replies.
robpowers3d
President, the LightWave Group
Recommended Instructions for Setting Up LightWave 10.1
Important Notes before installing:
LightWave currently uses a USB hardware key to license the software. Proceed
first with installing the software, then attach the USB hardware key before
you run the software.
Do not install the Lightwave 10.1 software over your v9.x series software!
If you have been using a beta version of LightWave 10.1, please delete
the configuration files related to those builds. After deleting these files,
new configuration files will be created after opening Layout and/or Modeler.
License keys issued for LightWave during a beta program cycle (prior to the
application going to what is called a Gold Master shipping status) are
typically 90-day keys, which have to be renewed after that time period expires.
Installation:
LightWave 3D now has 3 platform installers, as follows:
* MacUB: This includes 32-bit and 64-bit applications for Intel
Processors, all in a single application bundle. It is recommended you do not
install to a path that includes spaces.
* Windows 32: Runs on all 64-bit x86 processors and on those more
modern 32-bit processors that include the SSE2 instruction set. Does not
run on older 32-bit x86 processors that do not include the SSE2 instruction
set.
* Windows 64: Runs on all 64-bit x86 processors and requires a 64-bit
Windows OS.)
Installers are available by download.
1) Download the appropriate installer to your system and run it, or select and
run the appropriate installer from the Program Install DVD.
2) Follow the simple step-by-step instructions the Installer will provide
to complete your installation.
Windows Installer Note:
Please note that the Windows Installers include the Sentinel Driver
Installer. If you use the option to install the Sentinel Driver during
your LightWave install, please note that when the Sentinel Installer asks
you to restart the system/restart later, choose restart later, and click
finish on the Sentinel installer. You will see an error message indicating
that the Sentinel Installer has reported an error to the LightWave installer.
You can ignore that message.
Registering and Licensing
If you have installed and licensed LightWave 10.0, then at this point
all you need to do is to copy the License.key file from the
~/.NewTek/LightWave/10.0/Licenses folder to the
~/.NewTek/LightWave/10.1/Licenses folder. You should also follow the
registration instructions below to register your 10.1 upgrade.
If this is the first time you have installed LightWave, you are now ready
to register and acquire your license key to permanently activate your
copy of Lightwave 3D.
1) You need the serial number from your LightWave package if you have purchased
a new full seat of LightWave, or from your New Order Alert email if you
purchased an upgrade online from NewTek. The email may also refer to this as
a HardCORE membership number, and it will start with "AAM".
2) Attach the USB hardware key.
3) Run Layout. When Layout is first run, it will report that the
license.key file is not present and run in a limited "Discovery" mode.
A small panel will display the Hardware Lock ID, usually a five-digit number.
If you miss getting this noted when you start up Layout, you can go to the Help
menu dropdown, click on it, and select About LightWave 3D. The About box
will display the HardWare Lock ID just below the main logo at the top of the box.
4) When you have the serial number and the lock ID both ready, open a browser
window and enter:
http://reg.newtek.com/
5) This takes you to the NewTek online registration system. If you have not
registered a product with NewTek before, then Use the "New Registration"
option on the page to create a new account with username and password. Be
sure to put a valid email address into your account information, since your
license key and other important information will be emailed to you.
If you have already registered a product with NewTek, enter your username
and password to enter your account.
6) Once in your account, look for the Product Registration section on the page,
use the "Select your Product" dropdown to select "LightWave 3D" to register
a new full seat, or "LightWave HardCORE" to register an upgrade.
7) Next, you will get a page that has an entry field for the serial number.
Type in your serial number, and hit enter.
8) Next you will be presented with a field to enter your Lock ID. Type in
your Lock ID, and hit enter.
9) The system will now generate and display your license information, including
the permanent license key, a 16-digit number, with a dash between each
four-digit segment. Highlight and copy the license key.
10) Go to Layout, and from the Help dropdown, select "Enter License".
11) Paste the key into the entry field, and click on "OK".
12) Close and then relaunch Layout. LightWave should now run in fully licensed mode.
If you experience any problems with the automated registration system, you can also obtain
your license key by emailing your serial number and lock ID to [email protected].
NewTek Customer Service will send a return email with your permanent LightWave 10
license key within 48 hours, during the normal work week. Then use Steps 10 through
12 above to enter your license key in the product.
Important! Important!
Compatibility Notes on LightWave 10.1 Scene and Config Files
*Do not use 10.0 or earlier config files with 10.1, or vice versa.*
The best way to insure this is to allow 10.1 to use the default location that
it will create for its own config files.
If you are redirecting your config files instead of using the default locations,
then you must make sure you are not redirecting to the same location and thus
sharing the same config files between 10.0 and 10.1.
Also, do not run 10.0 or earlier version and 10.1 at the same time because they
will use the same Hub. When you are running one version of LightWave and decide
you wish to run any other version, you must shut down the applications and manually
close the Hub before launching the next version.
*Do not attempt to use LightWave 10.1 scene files using color space profiles
in v10.0 or earlier versions.*
There is a critical difference in that quotation marks are in use for many of the scene
file and config file color space parameters. This was instituted because many users are
using colorspace profiles with spaces in the path or the name. Adding the quotes is the
only reasonable option to address this.
This does mean that 10.1 Scene files and config files are going to confuse earlier versions.
Please understand, we will not be able to patch earlier versions to retrofit them for 10.1.
Users will need to observe the precautions noted above for operating 10.1 and earlier
editions on the same system.
Windows® Vista and Windows 7 Editions:
- Running without the Hub
- Running in "Isolate" Mode
- Creating Custom Config Files
One of the important changes is to the communications between the applications.
LightWave uses a module called the "Hub" to provide communications and data exchange
between Layout and Modeler. A means for not running the Hub has always been an option
for workflows where this exchange is not desired. To provide for a means of
interoperation of Layout and Modeler with other applications, operations have been
changed so that a new interprocess communications mode will be active when the Hub
is not active. When this new interprocess communication is active, Layout, Modeler,
and CORE will each update an object that they all have loaded, and which has been
changed and saved from one of the applications. Operation with no communications
is now accommodated with a new "Isolate" Mode.
For full discussions of these new modes and features, please see the manuals or help files.
For your convenience, we provide information below about how to run without the Hub, how
to run in Isolate mode, and how to redirect your config files for portability of your
LightWave folder, if you will be running from an external drive and changing systems.
The easiest means to run without the Hub is to locate and rename the Hub executable file
in the Programs folder of your LightWave 10 installation. Once renamed, Layout and Modeler
will not be able to locate and use it.
For those times when you do not want the applications to crosstalk at all, there is now
and "Isolate" mode, which both runs Layout and Modeler without the Hub, and turns off the
new interprocess communication. To run in the new "Isolate" mode you will need to set
up desktop shortcuts.
You can use the following steps to make Desktop shortcuts to run Layout and Modeler
without the Hub:
1) Locate the folder where you copied the LightWave 10 software.
2) Open the Programs Folder
3) Find the Lightwav.exe file.
4) Right-click and choose Create Shortcut
5) Right-click on the new shortcut and choose Properties
6) For Target, go to the end of the path and type -0
7) The entry should look something like this:
C:\Program Files\NewTek\LightWave10.1\Bin\Layout.exe -0
8) Repeat steps 3-7 for Modeler.exe
9) Use the shortcuts you created each time you open the software.
in Isolate mode (Hub also does not run):
6) For Target, go to the end of the path and type -i
C:\Program Files\NewTek\LightWave10.1\Bin\Layout.exe -i
Desktop Shortcuts to Redirect the Config Files
1) For Windows systems, enter the [username]\LightWave folder created by LightWave.
2) Create a new folder named "Configs".
3) Open the Configs folder and copy the path.
4) Navigate to the folder where LightWave 10 is installed, and enter the Programs folder.
5) Find the Layout.exe file.
6) Right-click and choose Create Shortcut
7) Right-click on the new shortcut and choose Properties
8) For Target, go to the end of the path and type -c
9) Paste the Configs path to the end of -c. If you have any spaces in
the Config path, put the path in quotation marks. The path should look
something like this (your exact path may be different):
C:\Program Files\NewTek\LightWave10.1\Programs\lightwav.exe
-c"C:\Program Files\NewTek\LightWave10.1\Programs\Configs"
10) Repeat steps 5-9 for Modeler.exe
11) Use the shortcuts you created each time you open the software.
robpowers3d
Desktop Shortcuts to run without the Hub,
and to Redirect the Config Files:
5) Find the Lightwav.exe file.
8) For Target, go to the end of the path and type -0 -c
C:\Program Files\NewTek\LightWave10.1\Programs\lightwav.exe -0
Desktop Shortcuts to run in Isolate Mode,
8) For Target, go to the end of the path and type -i -c
C:\Program Files\NewTek\LightWave10.1\Programs\lightwav.exe -i
Note for Windows Vista and Windows 7 Users
Vista's virtual store redirects files away from the traditional C:\Program Files
place where LightWave sits by default. LightWave does not recognize the Virtual
Store so there are two things that can be done. One is to install LightWave in
a non-traditional location, such as C:\NewTek\LightWavev10.1, the other is to
temporarily turn off UAC. To do this, open your Control Panel and just type UAC.
You don't need to click anywhere to do it. This will open up a window asking if
you want to leave your computer unprotected by turning off UAC, but you only need
to do it for registering LightWave. This will require a reboot of the system.
Alternatively, you can hit the Windows-r keyboard shortcut, type "msconfig" and
go to the Tools tab in the window presented and select Disable UAC.
Then you can load Layout (with the blue icon), go to the Help menu and choose
Enter License. Once you have pasted your license.key number in (16 digits, with
hyphens between each four like so: 1234-5678-9012-3456) and restarted LightWave,
you can turn UAC back on.
Mac Universal Preferences and License Keys
The license.key file for a single user, and user-specific settings should go in:
~/Library/Application Support/NewTek/LightWave/10.1/licenses
Any license.key file you want all users to have access to, and machine-
Third party plug-ins for the user (as they start showing up) should probably go in:
~/Library/Application Support/NewTek/LightWave/10.1/Plugins/
Third party plug-ins you want all users of your machine to have access to
should go in:
The Extensions configuration file used to contain a list of all of the plug-
ins you're using. Since we're using an automatic search now, the Extensions
file will be empty by default. If the user manually adds a plug-in via the
Add Plugins command, or by any non-automatic means, it will show up in that
file. We're trying to move away from this mechanism, but we've left this
capability in, in case you really need it.
Any objects or scenes you drag and drop into LightWave windows will not
change the content directory.
Instructions for creating and placement of the license.key file in the
Universal Binary:
1) Open TextEdit.app
2) Paste your permanent key on the first line
3) Select the 'Make Plain Text' item in the Format menu
4) Save the file. Name the file 'license.key', and place it in any one of the
following folders:
Support folder, which is in the main LightWave program
folder, next to Layout, Modeler, and other LightWave tools.
5) Open Layout to confirm that the key worked.
Mac Universal Binary: Running Without the Hub
in the same folder containing the Layout and Modeler applications. Once renamed, Layout and Modeler
Launching From a Script to Disable the Hub
or the Hub + IPC on the Mac
For users who would like to have something they can mouse-click on to launch Layout, Modeler,
or another application with specific arguments passed to it, it is simple to create a "bash"
script to accomplish this. In the examples below we will set up a script to run without the
Hub, which engages the inter-process communication (IPC) that lets Layout and Modeler talk
to one another and to other applications that support this new mode, and a script to run
the applications in Isolate mode, with both Hub and IPC off, so the applications do not
communicate with one another.
In our example scripts we will run Layout with the proper arguments for running without the Hub,
and for running in Isolate mode. The same approach can be used to launch Modeler and other
applications, as well as to specify other arguments than we have shown in the examples.
Script for Running Layout without the Hub
1. Launch /Applications/TextEdit by double clicking its icon.
2. Enter the following text into the edit window. It is important to have the ".app" extension
included in the filename. The location of your LightWave installation may differ, so adjust as
needed.
#!/bin/sh
open /Applications/NewTek/LightWave3D10.1/Layout.app --args -0
3. Save the text file to your desktop as "Launch Layout NoHub". Make sure to avoid a ".txt"
extension when saving.
4. Open a Terminal window using the /Applications/Utilities/Terminal application.
5. The script must be 'executable' so it will launch as a command when double-clicked with the
mouse instead of opening as a text file. Make sure the current working path is the desktop
(enter "cd ~/Desktop" if necessary) then enter this command.
chmod +x "Launch Layout NoHub"
Note that on some OS configurations, you may need to prefix the file name with ./;
and to avoid quotes, the spaces need a \ before them; so, either this:
chmod +x "./Launch Layout Isolated"
or this:
chmod +x ./Launch\ Layout\ Isolated
may need to be used instead.
6. Now, you can simply double-mouse-click the icon to launch Layout without the Hub.
Script for Running Layout in Isolate mode
needed.
#!/bin/sh
open /Applications/NewTek/LightWave3D10.1/Layout.app --args -i
3. Save the text file to your desktop as "Launch Layout Isolated". Make sure to avoid a ".txt"
5. The script must be 'executable' so it will launch as a command when double-clicked with the mouse
chmod +x "Launch Layout Isolated"
or this:
6. Now, you can simply double-mouse-click the icon to launch Layout in Isolate mode.
Mac Universal Binary: Redirecting Config Files
UB LightWave configuration files can be changed by placing the 'redirected'
config files into a folder named "Preferences" in the same folder containing
This allows the config files to 'follow' the location of the UB applications,
such as being placed onto a USB flash drive.
Alternatively, it is also possible to place config files into a
"Support/Preferences" folder, which can be used to avoid cluttering
the folder containing Layout and Modeler apps. The former folder supersedes
the latter, and both supersede a user's "~/Library/Application Support/NewTek/LightWave/10.1"
folder.
Mac Dongle Notes
Rainbow Eve3 Dongles:
Exchange Needed for 64-bit Cocoa LightWave
LightWave 10.1 brings both 32-bit and 64-bit Mac support to
LightWave users for the first time. One of the issues that users will
need to be aware of is that only the Sentinel framework is provided for
64-bit operation, because SafeNet does not have plans to port the Eve3
Framework, which is required for the Mac-only Eve3 USB Dongles. If
you have an Eve3 USB dongle and you plan to use the 64-bit version of
LightWave 10, you will need to exchange it for the current Sentinel Ultrapro
Dongle.
You can determine if you have an Eve3 dongle by checking the engraved
logo on the top, where it will say Rainbow/Eve3.
Folks who have an Eve3 dongle can call or email Customer Services to
request that the replacement dongle be sent out. There will be at most
a small charge for the dongle exchange, the replacement will ship immediately
upon request, and the customer can return the Eve3 dongle that is being
retired after receiving and getting set up and running with the new
Ultrapro dongle and new dongle ID.
NewTek will also provide confirmation of the exchange to any third
parties from whom the user has products that key to the dongle, as for
example do Worley Labs products. If you round up the necessary fax
numbers or email addresses for your third party products, you can provide
that information in your first call or email to NewTek CS, and that will
enable the CS staff to send out the confirmation notices very quickly
after entering the order.
Please note that we are not able to provide an exchange unit with the same
Lock ID number that you currently have. If you have third party plugins that
are keyed to the dongle but are no longer supported, you will not be able
to use those plugins with the new dongle.
Rainbow/SafeNet Duo Dongles:
Notes for Use with 32-bit and 64-bit Cocoa LightWave
Originally, Rainbow was the company that made the dongles used by LightWave 3D.
Rainbow was later acquired by SafeNet, so some Duo dongles are labeled Rainbow and
some SafeNet. The Duo dongle information below applies to all Duos, regardless
of which company name they show.
The Rainbow or SafeNet Duo dongle supports both the Eve3 Framework and
the Sentinel driver. For LightWave 3D 10 64-bit the Sentinel Driver is used,
and so will report a different Lock ID than did your 32-bit Mac LightWave 3D.
Registration needs to be updated to allow for this, so for now users with Duo
dongles will need to contact Customer Services in order to get a license key
for 64-bit Mac UB, as Registration is generating a key based on the Eve3
lock ID.
Please note, however, that if you have also registered the Windows Lock ID for
your Duo Dongle, then Registration may have generated an Open Beta license key
for that ID, and if so, that should work as well for 64-bit on Mac.
NOTE ABOUT CONFIGURATION FILES
If you have been using a beta version of LightWave 10, please delete
robpowers3d
3rd Party License Notifications
All 3rd-party license notifications are located in the <installation>/docs/Licenses/ folder.
Status
