Hasan Kara
I wonder if HLS Stream will be available in the future. Our state TV Channel uses HLS Stream to their CDN. Maybe it will be good to add this feature.
Thank you, did you try it?To view or publish? You can goto the add ons and IP sources and add an HLS stream to be an input on the tricaster.
Yes I did try it a while back and I was able to pull an HLS live stream in as an input and it worked well. Most of the time I think people opt to use SRT as a contribution feed across the internet with the Tricasters.Thank you, did you try it?
