Genlock Timing
AETN
I would be nice for the 3-play to remember the genlock timing information so it doesn't have to be re-timed every time we turn it on or reboot.
Thanks, Mike
SBowie
'the write stuff'
I don't believe this should be necessary now. We may need to bug this. Which model and, if you know, what software build are you running?
AETN
Hi Steve, Thanks
It is a 3PXD425
Build 1-4g-130715.11b
We have to re-time it frequently, I am not sure what is causing it to Jump
We are using HD Tri-Level Sync
SBowie
'the write stuff'
I asked QA about it, and this is their response: "That should be fixed. The latest build on the website is 1-5b. We have not heard of any genlock problems with 3play for a very long time."
(If you are running this latest build and it still happens, please submit a Fogbugz case, thanks!)
kanep
NewTek SE
I guess the question should be asked, is it just happening on a reboot/restart or when you start a new session on your 425?
BrandonHite
We have 4 - 425 units and they all do they same thing. You have to cycle the Gen-lock reference selector for it to actually sync to gen lock. All 425 units have the latest build and are up to date. Obviously it is NOT fixed.
