3dworks
archvizmacwaver
i really use this extremely useful plugin a lot to emulate the 'solo' function which you have in other programs for hiding all but the selected geometry temporarily in a scene. it is working as expected for opengl, the only problem is that it will not work with VPR. there is a button in the master plugin which is supposed to toggle also the active state for the selected object(s), but it does not work properly as when using the command 'show unselected' after a previous 'hide unselected', it will toggle ALL objects to ON, regardless of the previous states in the scene.
is there an alternative to this plugin or would it be easy to fix by someone? 'EF item focus' unfortunately does not work anymore correctly under opengl as well under LW 11.6.x.!
cheers
markus
cheers
markus
