EdgeSaw Script - feel like making it ?
Feel like making a script...?   :D
here's the challenge >
the script idea >
Run Connect tool
Switch to Poly Mode
Run Fix 3-5 Script
Contract Selection
Merge Polygons
Run Untangle
thekho
Motorball Champion
daforum
da what?
the script idea >
Run Connect tool
Switch to Poly Mode
Run Fix 3-5 Script
Contract Selection
Merge Polygons
Run Untangle
Will your script run on multiple 4poly selections? ( ie: if you need to make 8 sided polys all over the ball in one go? )
no, i'm afraid it won't, only on 4 as seen.
thekho  Use Navel
thank you!  :king:  that should fix it! i will make a new video on it. sorry for the delayed reply.   :)
daforum
da what?
0. Select 4 polys
1. Run Connect tool
2. Switch to Poly Mode
3. Run Fix 3-5 Script
4. Contract Selection
5. Merge Polygons
6. Run Untangle
Cool technique erikals works perfectly as you demonstrated :thumbsup:
daforum
da what?
I noticed that the higher up the ball the less it worked ( when Fix 3-5 was applied an 8 sided poly wasn't created )
I'm guessing the flatter the 4 poly selection the better it will work - so very good on cubic objects or flat sided objects; and very handy for specific areas on spherical objects too.
A script is still a quicker way to do this but I will try to remember the steps.
Sensei
did a (long) video on PX Navel...
What you were doing here,
you could do as well in
Wrinkle http://wrinkle.trueart.eu
But it has built-in preset manager so you could even store settings and reuse them any time later in completely different project,
and give surfaces new names, automatically by tool.
With hundred such navels, it could be done with just a few seconds.
Just select some points, and click on Wrinkle, and pick up preset from drop-down.
