We have been troubleshooting an odd issue for a while and were curious what the community thinks. On a dedicated NDI Network we would like the ability to use up to 7 HX-NDI streams. At times one Standard NDI stream could be utilized as well. The Cameras we are using are all Marshall CV630-NDI PTZ UHD Camera’s all flashed with the latest firmware. These cameras are connected to an AV Line Netgear M4250-26G4XF-POE+ Switch connected to our Streaming PC via a 1Gig link. Max traffic that we usually see on this link is about 190Mbps when all of these cameras are going. AMD Ryzen Threadripper 2950X, 32GB RAM, RTX 2060. We can manage 6 NDI connections decently if the Cameras are set to 1080p30. 5 of the connections are the CV630’s using NDIHX Streams and 1 HDMI capture using NDI FULL stream. We experience these frame drops regardless of application as well. OBS, VMIX, and Wirecast all present these frame drops in the same manner. The oddest thing is the frame drops are only present after it passes through the Application Preview Window. The video sent directly from the Camera and/or NDI FULL stream is unaffected until it reaches this point. If this didn’t also affect the recording and the stream this would be a non-issue. But unless we are missing something frame drops are injected on our stream after we exceed 5 streams or so. We’ve performed basic network tests and nothing obvious is jumping out at us. We were just curious if anyone else has ran into a similar issue in their NDI setups and if they could help point us in the right direction. Thanks, Curt Cooper | |||||||
