Dropped Frames due to high disk usage?
SETVSpringfield
Using 3play mini, 3 HDMI inputs, simple setup. But when scrubbing, selecting and even playing I get constat dropped frames and a warning about high disk usage. Nothing else is running, why are the disks unable to handle the I/O Operations?
SETVSpringfield
kanep
NewTek SE
Go to the Help icon, then 'About 3PLAY' on the home screen, look at the build number. The most current build is 4-0-151123. You will notice that the last numbers are a date (Nov 23, 2015 in case what the build I've put up). If your build is earlier than that, download and install the latest update from http://new.tk/dl
SETVSpringfield
"15081311b" so my build is old. I'll try another update
Out of curiously, why doesn't the update button see that there's an update?
SETVSpringfield
I just updated the 3play and things have gotten worse. I've rebooted several times and the interface works smoothly but the video, transitions and DSKs are all lagging and choppy. I basically cannot use this machine during a broadcast today because of all of the performance issues with the device.
