Crashes upon launch?
lwaddict
Caged but Happy
I've reloaded it twice, no change.
"A Critical Error has Occured"
Any ideas?
Gateway Laptop w/Intel Graphics built in.
4gig RAM.
Just upgraded to LW11.6 with the bundle.
Took a bit but I got ZBrush GoZ working fine but now this doesn't even open?
Any help would be greatly appreciated (I know, I'm already anticipating a steep learning curve)
lwaddict
Caged but Happy
Hmm... I was told that when I ran into GoZ issues... Vue issues... and some mocap issues... never was it.
Are you sure?
jasonwestmas
Adapting Artist
Since you're talking about crashes on launch and chronosculpt loads perfectly on my nvidia machine. . .I'm about 75% sure. :)
spherical
Any ideas?
4gig RAM.
Is DEP set for essential Windows programs and services only or for all programs?
Have you tried running it as Administrator?
spherical
If you do, other programs may have problems and you then have to add them to the exclusions list. I went round and round for a day trying to figure out why my SSH2 terminal app suddenly refused to start; the OS generating its normal less than actually informative error message that is impossible to search for a solution with. Tried all manner so stuff to debug. Nada. Getting away from it for a moment and pumping some blood from my legs into my brain by walking around, it struck me that while trying to get the MYST games to install on Win8, I had set DEP to "everything". Sure enough, I looked and DEP was as I had thought. Set it back to "only essential Windows programs" and away the terminal went! :|
jwiede
Electron wrangler
If Chronosculpt fails when DEP is enabled (and I'd be shocked if that were the case), that's a bug that needs to be reported and fixed. No apps within the last decade or so have legitimate justifications for writing to memory pages marked as executable (which is what DEP catches, triggering an app-fatal exception).
Rollie Hudson
Flipbook Productions
ChronoSculpt [705] version 1.0.0 for the Mac using Mavericks (OSX 10.9) - 30 October, 2013 pre-release is repeatedly crashing upon attempted launch. It immediately generates a "Chronosculpt quit unexpectedly" error message with problem details and system config info (Problem Report).
I can send the report as a PDF if needed. Also, I didn't see a BUG Thread for ChronoSculpt in the forums.
Rollie Hudson
The final release of Chronoscuplt 1.0 [4076] (31 October, 2013) is unfortunately also crashing upon attempted startup each time in OSX 10.9 (Mavericks). I've also tried to launch CS from the app icon directly inside the "bin" folder, with the same result.
  • ChronosSculpt Problem Report (build 4076).pdf
Darkcat
I was able to successfully install "ChronoSculpt" by erasing everything on my hard disk and using an old backup copy of mountain lion On my Mac time capsule. It was working fine from my (Mountain Lion) but once I upgrade everything back to (Maverick). The program Would not open.
I contacted NewTek to see if they can help me with this problem they said they'll have a new software for Maverick in the near future.
So you are dying to use the software; save all the software that you already have an Downgrade back to Mountain lion.
:devil:
