clip trim macro
in looking at the various ways to trim the in point on a clip, just need to backup the in point 2seconds (yes... to cover the transition for cued playback) i have noticed mixed results when applying the macro
for example
local-jog -50
mark-in-update
seems to work on some clips but mixed results on others
i did try a
set_item_prop
macro, but that ended up applying the same timecode to all other clips
i am curious what is the best command for an "any clip" situation
many thanks in advance!
-r
Ugh, this is from Tricaster DDR not 3play, not sure if they have this macro command:
Try with _scrub_to_time_from_beginning with a value of -2 then a _mark_in
for output its _scrub_to_time_from_end and _mark_out
