robpowers3d
President, the LightWave Group
The LightWave 3D Group has released a new update, ChronoSculpt 1.0.1
Please log into your account and view the list of Registered Products to download the latest version of the software.
This update adds support for Linux.
ChronoSculpt(tm) Change Log - December 23, 2013
Version 1.0.1
Linux 64 bit support (Specifically CentOS)
Corrected Alembic loader xpath/xname properties to allow loaded Alembic content to be saved properly in a CS project.
Added the generation of a Trial serial to the Splash Screen.
Reduced CPU usage on the Mac
Fixed animation offset on Alembic export
Made project formats preserve edits made in setup/global mode.
Moved clip on loading to original user's intended position. Note that this has no effect on Alembic caches which can use a quirky time offset.
Corrected frame offset issue within a clip.
Fixed erroneous "point count mismatch" warning
Made ctrl and command do the same thing on OSX.
CSA project file loading fixes
Mac startup path fix
Localization fixes
BUILD 2013/10/30
More GUI Refinements
Multiple meshes/caches can now be saved/loaded, preserving the original hierarchy too.
Preserving the Alembic hierarchy on export (depends on a valid Alembic file to be loaded into CS)
Fixed case #66814 - chrono sculpt feedback : Alembic output from Chronosculpt has different rate of speed
Fixed case #65871 - Chronosculpt: Unable to save morph edits using the abc format.
BUILD 2013/10/23
GUI Refinements
Timeline zoom and scroll feature added.
About command added to File menu
Quit command added to File menu
Splash screen displays ChronoSculpt version, build date and serial number information.
User settings like window size and tablet mode remembered between sessions
User Shortcuts can be adjusted by editing this text file : bin\cs\startup\CsShortcuts.lua
BUILD 2013/10/09
This build contains Playback controls, soft pinning and a change in it's native file format for saving.
Until recently, the ChronoSculpt projects were saved as pipeline-friendly (but large) text files
The new build saves out the exact same ASCII format with a *.csa extension instead of *.csculpt_text, and also offers a more compact binary-save option with a *.csb extension.
BUILD 2013/09/18
This build adds support for the Mac OS.
BUILD 2013/09/10
This build contains fixes for stability, licensing, and Alembic export.
ChronoSculpt(tm) now generates log files and crash dump reports during sessions.
Some of the specific fixes implemented:
- Started working on a fallback for systems that don't have hardware
acceleration.
- Alembic mesh/cache exports are now formatted so that the Maya Alembic
importer can load the file.
- A mapped-drive fix for Windows licensing, so that ChronoSculpt
can be installed to a network-mapped drive.
- More informative licensing error messages
- Installed a crash handler to support post-mortem debugging
- Added logging functionality. This can be useful for narrowing down where
users have a problem. On Windows, these log files get written to:
C:\Users\<USERNAME>\My Documents\ChronoSculpt\log.txt
Where <USERNAME> is the login name on your machine.
__________________
Version 1.0.1
Localization fixes
BUILD 2013/10/30
BUILD 2013/10/23
GUI Refinements
BUILD 2013/10/09
BUILD 2013/09/18
BUILD 2013/09/10
acceleration.
__________________
