Can't Get Daul monitors to work in XP Pro
David
VT[3] UNTIL HDV
I can't get windows Xp pro to spann Toaster across both monitors. I am using an nvidia Geforce ti 4600 with driver 41.09_win2kxp. I have all the setting set to allow spanning, but the device manager dosen't indicate a there is a secondary display device. I tried to add one useing the add hardware wizard but there are no nivida drivers in the manual settings, and the supplied disk dosen't have one on it either.
Please Help!!!
David
VT[3] UNTIL HDV
Dexter VTNT Yahoo posted this.
From Dexter on the VTNT yahoo forum's comes the answer:
"It's quite simple. I found when I installed XP that I had lost my second monitor and spanning. XP had removed my old driver and replaced it with their own. I unistalled that driver and installed the latest driver (rev 41.09) from NVidia's website. After the new driver is installed, right click on the desktop and open Properties. Click on the Settings tab and set your color quality to 32 bits and the screen resolution to 1260x1024 on monitor 1. DO NOTHING with monitor 2, that is: leave it inactive. If you activate it as XP help instructions tell you, you will end up with dual monitors that you can't span across.
Instead click on Advanced settings and then on the GeForceWhatever tab. That opens a window with a smaller side menu at the side. Click on nView Display Mode and then click on the horizontal span button and you're in business.
To fool around with dialog box and tool bar placement, drop down in the side menu and click on Desktop Utilities, then check Enable Desktop Manager, click on Desktop Manager Configeration and then click on the Wizard button. Some settings will work with your favorite programs and others will surprise you. Experiment until you get something you like."
Maybe this is good info for the FAQ or a troubleshooting/tips sticky thread.
