No offense meant, but I'm going to comment on some of this, for the benefit of others and in hopes of simplifying the process for those who go astray:
- Connect an SDI cable to the port on the camera
- Connect the other end of the SDI cable to a monitor
- Connect the ethernet port on the cam to your network
(Look at the SDI-connected monitor for the following steps)
- Hit "menu" on the remote
- Navigate to the "Ethernet" setting
- Select DHCP
- Switch to "ON"
The camera defaults to DHCP on. After a minute or two, if it does not get an address automatically from a DHCP server, it fails over to a static IP (192.168.100.168).
If you power it up some time
before connecting it to a network with a DHCP server, it may fail over to this static address. Something like this is almost certainly what happened to you.
- Go back to the main menu and select "Status"
- Go to page 7, Ethernet, and make note of the IP
- Exit the menu
- Using NDI Video Monitor, locate your camera according to the IP listed above
- If you can see it, so can the TriCaster.
To be a bit fussy here (to avoid any confusion), Windows users would use NDI
Studio Monitor (which is installed with the HX driver); Mac users have NDI Video Monitor (the older NDI Video Monitor for Windows wouldn't be of much help here).
In cases where a DHCP server was not found in a reasonable length of time after powering up, the static IP listed above should always work (it isn't different for different cameras). In that case, all you need to do is:
1) Connect the camera peer-to-peer to a computer,
2) set the computer's IP address to 192.168.1.1, net mask 255.255.255.0
3) access the cameras webpage and re-enable Dynamic IP Address (DHCP) by entering the static IP into a browser.
4) Then power down the camera, re-enable DHCP on the computer, and power the camera up again. Done.
Also, as a hint: if you connect and configure your cameras one at a time, it's generally unnecessary to bother finding out the IP number - just rename them as you go. If multiple cameras are online at any one time that all have the same name (the default is "Chan 1"), Studio Monitor will show the IP number next to the name, but as I said, if you rename them as you go, you can really ignore IP numbers.
Most if not all of this is in the docs. If you rigorously follow the 'getting started' steps, you will never have this problem. If you do, you can use SDI, the remote, and the method dhodlick describes, or just follow my steps 1-4.
