Bring an audio file in the node editor?
Hello
I'm trying to get an audio file to control some part move displacements in the nodal displacement editor.
Is there any way / node to do this?
Looked through the nodes, searched the forum, couldn't find a thing.
Thank you
UnCommonGrafx
Wandering about
I'm thinking:
You can extract audio data via the graph editor - bake the curve; put that into the node you want to control under the appropriate axis.
I would keep the audio for sync purposes, if needed.
Yeees! The audio channel in the graph editor. That's just enough. No need to bake for my use, I just apply It on any channel of a null and use the item info w pos, picking the right channel (x,y,z) to use that input as a controller.
Perfect, thank you!
