• Dear NewTek ( now Vizrt) community,
    We are merging and updating our forum to join it with the Vizrt Forum. Here's what you need to know:
    All existing threads, posts, knowledge articles, and user accounts will be seamlessly migrated.
    Once the merge is completed, the old forums will no longer be accessible.
    We are making this move to unite our Vizrt and NewTek forums, creating a new, enhanced experience for our community members and technology users.
    We will notify you once the change has been made and the new forum is live.
    Thank you for your continued support in our growing community!
Baking Camera - Can you bake one objects surface to another?
yeah you can.
use the surface baking camera.
http://www.lightwiki.com/Surface_baking
use this to do normals:
http://perso.orange.fr/dpont/plugins/nodes/NormalCast.html#NormalCast
put it on the low res surface, connect it to diffuse shading.
make sure you have a seperate surface for the low res and hi res objects.
hi res could have multiple surfaces
hi res might have a bump map on it, that would go into the normal map upon baking.
set your hi res object to unseen by camera.
set your low res object to unseen by rays.
bake.
just texture the hi normally and bake for cols\ambocc
Cool thanks for the links, I realised you could do the norrmals but what I realy wonder is if you can do all the regular surfaces, like colour, spec etc?
I cant see a clear way to do this.
Ultimately I would like to bake all of the textures on a highpolly model to a lowpolly model including any textures on the accessories and things such as belts & clothes etc. Like the plugin MicroWave would do.
Its for game models.
try..
set your low res object to unseen by camera.
set your hi res object to unseen by rays.
add PSD export to image filters & choose diff, spec etc
bake\render
I'm settings the lowpoly object to unseen by rays and camera so it does not affect the render at all. In the Surfacebaker camera I use the lowpoly mesh and it's UV map, an then I have to set the offset high enough so it covers the whole high-poly mesh, not uncommon to set it to 10mm or more.
And the PSD export idea from chunderburger is also a very good one. I personaly need only the color and occlusion map (2 separate renders).
Cheers yeah I got it working. Thanks all for the help.
JohnMarchant said:
Sorry Denis getting an error when trying to download this.
Thanks for report, I have fixed the link.
Sammael said:
What does this node do diferently that LW cant do natively? ...
Normal & Surface Cast get texture from one geometry,
even if it has different UVmap, this two nodes do a ray-intersection
of the surface of the hi-res or model to catch,
along the smoothed normal of the low-res object, which
can get its value(s) for baking into its own UVmap.
Normal Cast can work in "Tangent Space" which is better
for mapping the normal of animated objects.
Denis.
Denis.
Um, I've been doing this just using the surface baking camera using the low poly UV and having the low poly object unseen by camera. Then set up the distance from the lo poly surface you want the ray to be shot from in the camera. I'm not quite getting why your plugin would be different :p
i dont see the surface cast node in your links
did you remove it?
I would have like to use it. Its easier to chuck a node on your surface.
im wondering, could you hook up one node to bake all your info to a PSD in one go?
tangent normals, cols, spec, diff, occlusion etc
that would be neat.
so you just add the node and check the boxes for what you want and it spits out a file or files.
I guess what you really want is a proper baking pannel where you setup all this stuff.
Yes I have remove it, as said Dodgy here and Duke in another thread,
you can do this directly and faster in Surface Baking Camera
and export Photoshop_PSD plugin,
except for tangent normal map which needs a transformation.
Normal Cast Node does it in the color channel, because there is
not specific buffer for normal map, so it should be baked separetly.
If you want a whole baking system, as said before, there's still the
expensive Microwave plugin, a pixel filter plugin.
Denis.
chunderburger said:
try..
bake\render
Just to take this sideways a a little bit, I have a question. Is PSD export any better than Render Buffer View ? As far as I am aware, RBV can't 'see' certain buffers if they are driven by nodes. I.e it can't 'see' raw specular values even though the renderer can render them. In fact I'm not sure it can see anything other than diffuse shading, or 'shaded diffuse' I can't remember which off hand. That's been my experience anyway, that values/channels driven by nodes are not available to RBV as 'raw data' in the way they would be if driven by old-style layers.
Denis.
ah, i see in another thread that SB camera doesnt respect smoothing.
would your node respect smoothing? if so it is then very useful
Back
