baby steps with my first node, please help
IRML
Devastatin'
I am very noob at this, I'm using visual studio community and all I am trying to do so far is just get the example source "specular_node.c" to build and run, before I attempted to do anything of my own
so far I have got the "server.lib" and "specular_node.c" to build in win32, but I get these errors if I try x64:
Code:
Error (active)	E1696	cannot open source file "lwserver.h"				server	d:\LightWave 2015 SDK\source\servdesc.c	16
Error (active)	E0020	identifier "ServerUserName" is undefined			server	d:\LightWave 2015 SDK\source\servdesc.c	21
Error (active)	E0141	unnamed prototyped parameters not allowed when body is present	server	d:\LightWave 2015 SDK\source\servdesc.c	22
Error (active)	E0130	expected a '{'							server	d:\LightWave 2015 SDK\source\servdesc.c	22
Error (active)	E0020	identifier "Activate" is undefined				server	d:\LightWave 2015 SDK\source\servdesc.c	26
Error (active)	E0065	expected a ';'							server	d:\LightWave 2015 SDK\source\servdesc.c	26
Error (active)	E0029	expected an expression						server	d:\LightWave 2015 SDK\source\servdesc.c	26
Error (active)	E0065	expected a ';'							server	d:\LightWave 2015 SDK\source\servdesc.c	28
Error	C1083	Cannot open include file: 'lwserver.h': No such file or directory	server	d:\lightwave 2015 sdk\source\username.c	14
Error	C1083	Cannot open include file: 'lwserver.h': No such file or directory	server	d:\lightwave 2015 sdk\source\startup.c	13
Error	C1083	Cannot open include file: 'lwserver.h': No such file or directory	server	d:\lightwave 2015 sdk\source\shutdown.c	13
Error	C1083	Cannot open include file: 'lwserver.h': No such file or directory	server	d:\lightwave 2015 sdk\source\servdesc.c	16
I see no mention of 64bit in the sdk, so I have no idea where to go from here
IRML
Devastatin'
ok the include files reset when you switch to x64, I repointed them and the server.lib compiles, but the plugin still does not, these are the errors I'm getting now:
Code:
Error	C3861	'__stosb': identifier not found				specular_node	C:\Program Files (x86)\Windows Kits\10\Include\10.0.15063.0\um\winnt.h		19111
Error	C3861	'__readgsqword': identifier not found			specular_node	C:\Program Files (x86)\Windows Kits\10\Include\10.0.15063.0\um\winnt.h		21336
Error	C3861	'__readgsqword': identifier not found			specular_node	C:\Program Files (x86)\Windows Kits\10\Include\10.0.15063.0\um\winnt.h		21347
Error	C3861	'_InterlockedIncrement': identifier not found		specular_node	C:\Program Files (x86)\Windows Kits\10\Include\10.0.15063.0\um\winbase.h	9023
Error	C3861	'_InterlockedIncrement': identifier not found		specular_node	C:\Program Files (x86)\Windows Kits\10\Include\10.0.15063.0\um\winbase.h	9032
Error	C2065	'InterlockedIncrement64': undeclared identifier		specular_node	C:\Program Files (x86)\Windows Kits\10\Include\10.0.15063.0\um\winbase.h	9044
Error	C3861	'_InterlockedDecrement': identifier not found		specular_node	C:\Program Files (x86)\Windows Kits\10\Include\10.0.15063.0\um\winbase.h	9055
Error	C3861	'_InterlockedDecrement': identifier not found		specular_node	C:\Program Files (x86)\Windows Kits\10\Include\10.0.15063.0\um\winbase.h	9064
Error	C2065	'InterlockedDecrement64': undeclared identifier		specular_node	C:\Program Files (x86)\Windows Kits\10\Include\10.0.15063.0\um\winbase.h	9076
Error	C3861	'_InterlockedExchange': identifier not found		specular_node	C:\Program Files (x86)\Windows Kits\10\Include\10.0.15063.0\um\winbase.h	9090
Error	C3861	'_InterlockedExchange': identifier not found		specular_node	C:\Program Files (x86)\Windows Kits\10\Include\10.0.15063.0\um\winbase.h	9100
Error	C3861	'InterlockedExchange64': identifier not found		specular_node	C:\Program Files (x86)\Windows Kits\10\Include\10.0.15063.0\um\winbase.h	9112
Error	C3861	'_InterlockedExchangeAdd': identifier not found		specular_node	C:\Program Files (x86)\Windows Kits\10\Include\10.0.15063.0\um\winbase.h	9124
Error	C3861	'_InterlockedExchangeAdd': identifier not found		specular_node	C:\Program Files (x86)\Windows Kits\10\Include\10.0.15063.0\um\winbase.h	9134
Error	C3861	'_InterlockedExchangeAdd': identifier not found		specular_node	C:\Program Files (x86)\Windows Kits\10\Include\10.0.15063.0\um\winbase.h	9144
Error	C3861	'_InterlockedExchangeAdd': identifier not found		specular_node	C:\Program Files (x86)\Windows Kits\10\Include\10.0.15063.0\um\winbase.h	9154
Error	C3861	'InterlockedExchangeAdd64': identifier not found	specular_node	C:\Program Files (x86)\Windows Kits\10\Include\10.0.15063.0\um\winbase.h	9166
Error	C3861	'InterlockedExchangeAdd64': identifier not found	specular_node	C:\Program Files (x86)\Windows Kits\10\Include\10.0.15063.0\um\winbase.h	9176
Error	C3861	'_InterlockedCompareExchange': identifier not found	specular_node	C:\Program Files (x86)\Windows Kits\10\Include\10.0.15063.0\um\winbase.h	9189
Error	C3861	'_InterlockedCompareExchange': identifier not found	specular_node	C:\Program Files (x86)\Windows Kits\10\Include\10.0.15063.0\um\winbase.h	9200
Error	C3861	'_InterlockedCompareExchange64': identifier not found	specular_node	C:\Program Files (x86)\Windows Kits\10\Include\10.0.15063.0\um\winbase.h	9213
Error	C3861	'InterlockedAnd64': identifier not found		specular_node	C:\Program Files (x86)\Windows Kits\10\Include\10.0.15063.0\um\winbase.h	9223
Error	C3861	'InterlockedOr64': identifier not found			specular_node	C:\Program Files (x86)\Windows Kits\10\Include\10.0.15063.0\um\winbase.h	9233
Error	C3861	'InterlockedXor64': identifier not found		specular_node	C:\Program Files (x86)\Windows Kits\10\Include\10.0.15063.0\um\winbase.h	9243
Warning	C4090	'argument': different '__unaligned' qualifiers		specular_node	C:\Program Files (x86)\Windows Kits\10\Include\10.0.15063.0\shared\stralign.h	120
Sensei
These are from standard/system libraries..
If you don't know function google for its name.
In their descriptions should be written in which link library they reside.
IRML
Devastatin'
I just installed all the extras visual studio comes with and still get nothing, I don't get it, it compiles just fine in 32bit
