Augmenting conductor node ?
byte_fx
I would like to use conductor material as the base surface then overlay that with an image map of a painted surface and a mask image to allow the conductor surface to show through where the paint has been worn away.
Is there a way to do this?
Thanks.
Lightwolf
obfuscated SDK hacker
You can also use the simple Material Mixer node which comes with LW. It only allows you to mix one material with another... but if that's all you need then it's simpler to use.
Sheesh, I can't believe that I'm actually arguing against my plugin ;)
Cheers,
Mike
byte_fx
thanks for the tips. i'll check them out.
not to worry lightwolf - i have some of plugs and they're great.
