Audio by Airsend Talkshow
alonso
Hi friends
I'm trying to send the audio from my tricaster mini to the talkshow
on the talkshow in "input connection" I choose Tricaster 42f9075C ( that's my mini) and have video and audio! but the audio is very clipped
there is something that i'm not setting well?
thanks
Edit: After several hours of testing :D
I see that when i choose Follow 1 or follow 2 have that problem
but if i choose and independent source the audio sound awesome
all of these only happend when i work in a sesion 720p
in 1080i i don't have problems
alonso
Hi Mr SBowie :D
Look
https://youtu.be/ZUNo-tjhwQw
The audio that you hear come from the Talkshow , look that the audio is normal when i choose camera 1 or DDR or net on the Network connection but when i choose follow 1 or 2 audio is bad.
this not happend on a session 1080i
SBowie
'the write stuff'
Staff member
That's helpful, thanks. Your clip doesn't show the TC audio mixer. I had asked about your mixer settings for the outputs you're following. I'd like to assume the settings are within normal limits, but assumptions tend to bite. ;)
p.s., it might be helpful to know which software versions you are running on both units.
alonso
Thanks SBowie
MrTalkshow version: v1.0.8902.40
Tricaster mini Version: 2-4-150121
YEs the sound is between normal range.
Before send an audio, i test it with a microphone i have these problems too.
SBowie
'the write stuff'
Staff member
Well, let's see:
You appear to be sending a composition from M/E 4 to PGM, and PGM to Output 1, along with audio from the Sound player only. OK.
But I'm a little puzzled by your Net 1 source. It appears to be the TriCaster UI. Where is that coming from? I rather suspect this may relate to your problem.
alonso
Hi Mr SBowie, I run IVGA in the tricaster itself, in order to take the picture :D .
on the video output no matter what i'm sending, M/4 , cam 1 DDR NET, the audio have the issue when I mark Follow 1 on the Network
the same configuration in a new proyect 1080i is perfect no problem with audio using the same workflow.
SBowie
'the write stuff'
Staff member
Aah, clever workaround.
I understand that.
OK, I'm confused again. Are you saying that this problem only occurs in one particular session?
alonso
Yes only with session that are 720p, I create 2 different session and have the same issue. only in 1080i not have any problems.
