Alembic export stripes out UVs
giuseppe80
Hello,
I export my Alembic cache with UVs from Maya 2014,
import it in Chronosculpt, I do my sculpt and then
export the Alembic cache again.
I import this cache in Katana or Maya but unfortunately the UVs are gone,
they are not attached to the geometry anymore.
This result makes unusable my Alembic cache.
Any workaround or fix?
Giuseppe
jasonwestmas
Adapting Artist
What you want to do is just merge the cached animation back onto your original models, don't replace the models.
giuseppe80
Hi Jason
do you mean to do it with Maya cache? Because with Alembic you can't do what your are suggesting.
Giuseppe
jasonwestmas
Adapting Artist
In Maya did you try the Animation-Menu> Pipeline Cache> Alembic Import? In Alembic import there is a setting called "Import Under Current Selection" > Merge with two check-box options. I have successfully merged abc point cache onto meshes without having to replace them.
giuseppe80
Thanks Jason,
I gave a try but it didn't work.
Do you want I send you my Alembic cache this way you could try too?
Another weird thing is the export of the Alembic from Chronosculpt:
1) the Alembic file, with UVs, from Maya is 40 MB
2) the Alembic file from Chronosculpt is just 8MB, ok it is without UVs but the UVs info weights just few kilobytes not 32MB!!!
3) the Alembic cache exported from Chronosculpt has also a different subd level from the one exported from Maya...
Thanks,
Giuseppe
jasonwestmas
Adapting Artist
I found a workaround that isn't too bad.
-) Instead of merging, use the alembic import to scene root option. You'll then have the sculpted mesh from Chrono without UV and the UV mesh that you already have inside of maya.
-) The two meshes should overlap each other exactly at this point. Select the UV mesh and then your target mesh without UV. Use the Polygons> Mesh> Transfer Attributes tool to transfer UVs to your imported abc mesh.
-) Select your imported mesh that has the newly transferred UVs and then go to Alembic Cache> Export Selection to Alembic. Make sure the UV checkbox is checkmarked in the options.
-) Now simply import your new abc mesh that has the UVs and cache together now (merge might not work) and apply your materials/textures to that object, cache should still be intact.
I'll report this issue to LW3DGroup
