Alembic changing topology files
octaviuzz
Hi there,
trying the demo of CS , I loaded an alembic fluid mesh, it is one file but contains a frame range , fluid simulation meshes...the problem is that there is some issue with the polygons jumping to random vertices.
The first frame load fine, but from then on they are just a mess,,,i guess CS doesn't handle changing topology with the resulting changing vertex order.
Is there a way to get around this, like a ignore previous vertex order,,or clear the buffer every frame...or something else?
thanks
O/.
