About transcoding clips
trebede
I'm working with a Tricaster TC1 with last firmware update. I'm working with clips generated in Edius and exported as .mp4 files.
When I play these clips the playback is correct but if I transcode the file because I get the T in the interface the playback is not correct and the clip goes "jerky".
As far as I know this transcoding should not create this behavior as it transcodes it to the best format for playback.
Can you tell me why this behavior is happening or what am I doing wrong?
Thank you very much for your help
SBowie
'the write stuff'
Staff member
There are no user-accessible controls for the transcoding process, so there's not much you can do here as far as I can see. It might be worthwhile in this case to prepare a small example file from Edius, confirm that the problem manifests itself after transcoding, and then submit the original mp4 for examination in a Fogbugz case.
