3Play Mini & Novation Launchpad Mini
SETVSpringfield
So I've been using these two without issue for a while. All of a sudden today, the lauchpad will not light up. In the Novation Launchpad app, I have all the colors set. In the macros, they can see that I press the button (when I click Listen...), however the macros already programmed will not execute, and NONE of the lights match the profile I had set up in the applet. What on earth is going on?
This also just happened after I updated the 3play today.
SETVSpringfield
I found the issue, and it seems really stupid.
We use a USB hub for keyboard, mouse, and Novation pad. And when plugged into one port the pad works fine, plugged into a different port, it's as if a whole new never before seen pad was added to the system.
I still had to reconfigure the colors since the update lost them.
So the issue is fixed so long as we keep the USB pad plugged into the exact same port every time
