On the old 3Play systems when you use the shortcut keys on the panel to use hotkeys to name a file. This data was used as the filename when exporting
On the 3P1 this is not the case and you have to manually rename each clip.
This slows down the speed of being able to push clips out to our FTP server which in turn delays delivery
Please can this work as it does on all the other 3play systems.
Thank you.
NOTE: I had previously put this into the Tricaster requests section, didn't realise this section was here. Thanks
Thank you.
