ia rendering 16:9 possible?
or do i have to start with a 16:9 project.
I should know the answer to this question.
but checking to see if it is possible with 3D arsenal.
You'll need to go to your Camera's Item Properties (select Camera at the bottom of Layout, then next to it select Item Properties). The second option from the top should be "Resolution" change it to D1 (NTSC Widescreen) to do a 16:9 render.
In lieu of a 16X9 version, what about developing a script that will modify the 4:3 version, not only updating the camera settings, but also mappable panels? Seems like that would be a relatively quick fix.
Also, any ETA as to when we can expect 16X9 support?
We are working on this but it's not quite that simple and there are several new things taking priority over that at the moment.
We will support 16x9 mapped images in the future but I don't have a timeline for you at the moment.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
