007
John Perkins
NewTek Staff
This is a really tricky set, so I'm not sure how useful it is, but it was fun anyway.
Set up your LiveMatte key settings first.
Turn on the LiveMatte Preview and leave it ON.
Put your "flames" or whatever on the Effects row.
Apply the effect to your talent.
This set has a ton of quirky things you can do with it, but the intended effect is with the LiveMatte preview enabled.
By keying different colors in the subject and enabling/disabling the matte preview you can get some really cool effects.
Enjoy ;)
  • 007.zip
joseburgos
LiveSet Making Machine
Man how did you do that?
The black portion of the preview key leaks through a little.
This has what's on the effects bank showing through just a little.
How did you invert the matte.........
Thanks for the set,
SBowie
'the write stuff'
Staff member
Hehehe - I know, but I'll let John leak it in his own way and time ...
Nice application, John!
John Perkins
NewTek Staff
Heh, yeah Steve, I figured you would get it ;)
It's a huge hack right now, that's why the it has the bleed through, but it's still fun to play with.
Cineman
John,
Just noted that, if you don't post the NewTek Forums again today, it would be good if you could post 65 times tomorrow. If that doesn't work for you, you could spread it out over some number of days. Just subtract the number of posts tomorrow from 65, and then add one more per day, or seven per week.
Now, how can I tastefully use enough Smileys to surround this post. Besides, I'll be censored for an inappropriate post on this forum.
Nes Gurley
hruffin3
How !
okay so please explain how it works - its like the old lock key - but i can't re-create this - using vt card not vt pro - everything i try ... can't get the matte to work like that:help:
hruffin3
does this work with vt33 card or only vtpro
i can't get this to work with vt33 card should it work ???? i can get the set to show but never get the matte o actually work.
