Results 1 to 8 of 8
Thread: Geometry-transparency
    Apr 2006
    san Diego
    254
    I'm trying to create a model using a Background image. Is it possible to control the opacity of the geometry so I can see/model the Background image?
    Engineer/Entrepreneur Sekhar's Avatar
    Sep 2005
    Pasadena, CA
    2,124
    Could you explain a bit more? Do you just want to see the background image through the foreground object? In that case, you could set the object dissolve (under render tab in object properties) for the object.
    Apr 2006
    san Diego
    254
    I want to model an extruded box into the background image. Problem is when you draw the box it hides the background image.
    I will try object dissolve.
    Registered User CGI Addict's Avatar
    Dec 2008
    California
    483
    Hey pdp, just apply a surface name to the polys and go into surface settings and give as much tranparency (%) as you want. Just make sure Transparency checked in the GL Tab in the Display Settings window.
    Michael Borjon
    www.pixelcollab.com
    Apr 2006
    san Diego
    254
    Wow that easy uh; I will give this at try this evening,
    thank you.
    Registered User Kuzey's Avatar
    Melbourne
    5,262
    Quote Originally Posted by CGI Addict View Post
    Haha....I was just wondering why transparency wasn't working anymore
    Kuzey
    Quantum Mechanic danielkaiser's Avatar
    Riverside CA
    1,056
    Quote Originally Posted by pdp editor View Post
    You could just set your view to wireframe.
    Daniel Kaiser
    "A mistake is always forgivable, rarely excusable and never acceptable." Robert Fripp
    AMD Phenom II x6 3.2
    Win 7 Pro x64
    8gig Ram
    Nvidia 640 GT 2Gb
    LW 11 x64
    Apr 2006
    san Diego
    254
    Wireframe; I never thought of that thanks again; both methods work well. This just goes to show the true value of this forum.
