Thread: Normalize scalar?
    Normalize scalar?
    Is there a way to normalize scalar output of a node?
    I have a node which is outputting huge range of numbers and would like to squeeze it between 0 and 1.0 or some other arbitrary values.
    Any tip would be appreciated. Thanks!
    incurable dumbass Medi8or's Avatar
    Norway
    803
    Divide node?
    (Divide by the max-huge-number..)
    My dongle is small, hard, and purple.
    Yes I thought of that... Problem is I don't know what is the max value... Anyways I figured out a workaround...
    Stuttgart, Germany
    13,543
    Do you really want to sequeze 0 to x into the 0 to 1.0 range... or do you just need changing numbers between 0 and 1.0?
    In the later case, mod should be your friend (it returns the remainder of dividing A by B, i.e. if you divide A by 10 then the remainder will be anything from 0 to 9, getting into the 0 to 1.0 range is just a division away in that case).
    Cheers,
    Mike
    Quote Originally Posted by Lightwolf View Post
    Cheers,
    Mike
    No, I realy need to squeeze 0 to x into 0-1 range. Any other clues on how to tackle this?
    Stuttgart, Germany
    13,543
    Quote Originally Posted by Jure View Post
    Without knowing the max value, no, not really.
    If you do know it then it's just a division by the max value.
    Cheers,
    Mike
    Cheers,
    Mike
    right.... thanks for help anyway!
