Thread: Rope question
    Apr 2006
    san Diego
    254
    Rope question
    Im trying to bend this object. How do I deselect the points located inside- see image.
    Change the viewport display to Wireframe and you can de-select them.
    Confirmed -
    Hastings, New Zealand
    7,731
    You can also click in the gray area around the screen or hit the / key.
    Apr 2006
    san Diego
    254
    Quote Originally Posted by SplineGod View Post
    if I do that all the points are deselected- not what I want.
    7,731
    Once you select some points and let go of the mouse button to deselect simply click on the points with the LMB or lasso with the RMB. To add to the selection do the same but hold down the shift key.
    Washington State, USA
    2,880
    This won't help you deselect the inner points, but once you have the selection just how you want it, you can make a selection set so you only have to go through the pain of a difficult selection once.
    As for deselecting the middle I'd do what Toby and Larry said. Switch to wireframe mode, zoom in on the left side and lasso select (RMB) the points on the inside leaving the outside points alone.
