Results 1 to 8 of 8
Thread: How to reset External Output
    Registered User NRBC_Media's Avatar
    Dec 2008
    Hampton Roads, VA
    76
    Is there a way to reset the external output to default settings?
    I confess, I was playing with keying and now my projector output has too much contrast. I can experiment with SMPTE bars, but was thinking there maybe a reset for those settings.
    Bloomington, IN
    1,604
    Try the reset configuration on the Admin screen.
    -Jeff
    My TriCaster Blog
    TriCaster Tally Lights
    Gear Used: TC1, TC 8000, TC 460, TC Mini 4i, 3Play Mini, 3Play 4800, TS 100, TS 4000
    Dec 2008
    Hampton Roads, VA
    76
    Thank you. I will give that a try.
    Dec 2002
    San Antonio, TX
    3,830
    Another tip to remember is that double-clicking ANY rotary dial in TriCaster, VT[5] or SpeedEDIT will snap the dial back to its default setting.
    Don't stream it - TriCast it!
    Sep 2004
    Los Angeles
    795
    Thanks Paul, I did not know that!
    Bob Anderson
    Dec 2008
    Hampton Roads, VA
    76
    I will now try that. The reset configuration did not do it.
    Thanks.
    Always Learning
    Tucson, AZ
    88
    Hi Paul does that "double click" include the headphone and audio master volume controls?
    Dec 2002
    San Antonio, TX
    3,830
    Quote Originally Posted by KWeaver View Post
    In that instance, Ken, you need to hold down Shift before double-clicking, at which point headphone, master or or mixer input levels go to Unity.
