Results 1 to 10 of 10
Thread: Exporting Flash
    Mar 2009
    Vancouver
    16
    Exporting Flash
    Why can't you export to a custom Flash profile? I'd like to be able to render an edited story directly to flv at 650 kbps, mp3 audio, with a 5 key frame.
    As it stands now, you have to export as uncompressed avi and transcode to a custom flv profile.
    With you, right now seem to still have only one .flv render option and it's 300k and not H.264.
    NewTek Certified Operator - TriCaster Professional Line
    TC 460 8000 / ATEM 4K 1 M/E
    Elemental Live / Teradek Cube/Bond / Wirecast 6
    Panasonic HE120 Sony F55/F5/FS7/EX3
    LinkedIn
    Mar 2009
    Vancouver
    16
    Bump?
    Oct 2008
    Reykjavik
    8
    I have a customer who really needs new Flash export settings - as detailed above by kevincanuck - and in 16:9 (i.e. 640x360!).
    Specially since the only current Flash Render option seems to squees 16:9 into 4:3.
    Isn't there any way to creat this and ad to the Render Preferences - as one can with live stream preferences?
    19,159
    I haven't tried, but I expect it is possible to use the main TC Record function, then use FME directly to convert the result to all manner of custom Flash formats. Someone who uses it might be able to offer more info.
    Mar 2009
    Vancouver
    16
    Anyone? Step-by-step instructions would be extremely helpful...
    FME 3.0 will not convert it.
    LinkedIn
    NewTek Engineering ACross's Avatar
    San Antonio
    794
    If you create your own custom flash profile and put it into the correct location on disk (I do not have it infront of me, but it should not be to hard to fine) ... we will then make it available through the UI.
    Caveat : Obviously going to very high bit-rates or resolutions might fail to encode in real-time ...
    Can certainly do that in the Live tab, but I don't see a file that is editable that's related to the Edit Media tab.
    If you use the Live tab to do it you have to sit there and hit play, and then record, and stop record etc. That's not an efficient workflow. If anyone knows how to edit those Edit Media profiles let us know. and if it's not that hard Newtek should consider just including additional profiles, the ones we have are outdated.
    Consultant
    Apr 2008
    Greater Washington, DC Area
    1,389
    Check for a posting by "billme" I think the screen name is. I remember reading it, thinking it was an interesting tidbit, but I don't remember where on the forum.
    He describes how to do this and where to put the files. Of course, you can also play out from TriCaster in real time (live or from DDR) and encode using FME in real time in whatever resolution you like. Because your TriCaster may or may not have enough processing power, it's up in the air how much you can push it. TriCaster BROADCASTs tend to have quad core processors. I think they are low end, but I don't recall. Studios may have dual or quad cores. TriCaster PROs are Dual core. Not sure about the original model or the duo.
    Sandy Audio Visual LLC
    NewTek Certification Testing Center
    Twitter @DCTriCaster
    TriCaster: All Models
    Cameras: Sony HDC-P1, X300
    My opinion, uncensored. The blog at www.sandyaudiovisual.com.
