Hi, I'm trying to get LW to output the rendered frames to a different directory (which frames go to which directory will depend on the frame contents). Using the LWSceneInfo global, it's possible to access the prefix used by the filenames using LWSceneInfo's RGBPrefix member. According to the docs, this appears to be read-only and there is no corresponding command for changing it. Is there any way of changing RGBPrefix when rendering different frames? BTW. If a different directory isn't possible, even changing just the prefix of the rendered filenames would be OK.
If this is not possible, I could just get the camera-plugin I'm working on to write a description of the frame to a file and use a separate standalone program to manipulate each frame-image according to the contents of the file.
Cheers,
AE.
