Page 4 of 5 FirstFirst ... 2345 LastLast
Results 46 to 60 of 65
Thread: Golf Ball
  1. #46
    I've put Spikey on my popup-menus since I'm using it often but it's somewhere in menues . Probably under Utilities/Plugins/Additional or so. Just go to Menues editing and add it where you want if you plan to use it often .
    RAM-Studio
  2. #47
    Mar 2008
    Prince Edward Island
    492
    How did you select the center poly after the Edge Bevel?
  3. #48
    Select N-Gons like explained here few times and showed on video - check out more closely 25sec of video .
    RAM-Studio
  4. #49
    Mar 2008
    492
    Great! Have a look. I will still play around, but thanks a ton!!
  5. #50
    Mar 2008
    492
    Thanks for everyones help.
    Attached is the Layout. Any advise / criticism great accepted.
Name:	Golf Ball copy.jpg
  6. #51
    Super Member ramccombe's Avatar
    Lemon Grove, Ca.
    387
    Dimples too shallow
    Congratulations, I think it looks pretty good though I might suggest making the dimples a little deeper.
    Richard .......
    1 Ghz TI PowerBook 10.4.11
    Dual 1 Ghz Tower 10.4.11
  7. #52
    Good and yes little deeper and it'll be perfect
    RAM-Studio
  8. #53
    Mar 2008
    492
    Thanks for the tips. I will make them a bit deeper.
    Could someone tell me what the sharp shadows are (see attached) & how to remove them?
  9. #54
    Lemon Grove, Ca.
    387
    Not sure.
    Quote Originally Posted by Stephen0523 View Post
    Pretty strange. Are they there without the texture map? Or maybe you have some stray points or geometry. Other than that, I don't know. I would first try removing the texture map (text) and render if that doesn't work then maybe check the stats windows in modeler(points, edges and polys) for strays. Good luck.
    Richard .......
  10. #55
    Mar 2008
    492
    One last question. Is there a way to re apply the Spikey Tool or select the insets to allow for a deep concave hole? See attached.
  11. #56
    Lemon Grove, Ca.
    387
    Not sure.
    I wouldn't bother, it just takes a minute to re-model. I went through the same thing trying to grab those points but spent more time trying than it takes to model.
    Richard .......
  12. #57
    Mar 2008
    492
    Agreed.
    Thanks.
  13. #58
    Lemon Grove, Ca.
    387
    No worries
    Your quite welcome.
    Richard .......
  14. #59
    What light type you've used to LIT scene ?
    RAM-Studio
  15. #60
    Mar 2008
    492
    Hi. Attached is am image showing the light. I may put in a fill light to bring out the edges of the ball. I also will create a ball with slightly deeper divets.
Name:	Picture 1 copy.jpg
