Results 1 to 14 of 14
Thread: QTVR Object.
    Registered User Andyjaggy's Avatar
    Sep 2003
    Utah
    4,327
    QTVR Object.
    What do you guys use to create QTVR object movies? Is there anything free out there that does a good job?
    Newbie Member falogfx's Avatar
    Sweden
    55
    You might already be aware of this but... if your objects are 3D based then you could use the QTVR Object exporter built into LightWave (Render Globals/Output/Animation Type - choose Quicktime VR Object) I haven't been using it for ages but it was quite useful back in 2000 or so. There isn't much control over the outcome, but for simple object spinning it does a good job.
    Setting up the scene might give you a headache though.
    For other than 3D objects I don't know what to use. Apple had their own software for creating QTVR movies long ago, maybe they still do...
    Sep 2003
    Utah
    4,327
    Yeah I tried the built in one and couldn't get it to work. Any guides or tutorials out there?
    normally i am different ingo's Avatar
    Close to the baltic sea, nearly in it
    1,904
    http://gardengnomesoftware.com/object2vr.php?lang=en
    Not free though but nice. For the rendering one should write a small script that places the camera, otherwise you have endless work placing the camera manual on each frame.
    ingo erik moltzen - virtual image maker --- www.im-graphics.com
    Sep 2003
    Utah
    4,327
    Do you have to have a codec to be able to view them in quicktime?
    Registered User Kuzey's Avatar
    Melbourne
    5,262
    No....they are just like a normal quicktime movie, with an extra tag or something that tells quicktime how to play/display them.
    However..you do need quicktime to view them.
    Kuzey
    Sep 2003
    Utah
    4,327
    Well I can't view them, I have the latest version of quicktime pro and it just comes up with a big question mark when I try to watch them.
    Melbourne
    5,262
    Mmmmm....can you view any of the examples here:
    http://stream.uen.org/medsol/digvid/...vr_movies.html
    The movies from that page work for me, I even saved one to my computer and opened it in QT player.
    Your movies might be the problem, either they have become corrupted or it's something else.
    Btw I tried this in XP on my MacBook.
    Kuzey
    Sep 2003
    Utah
    4,327
    Nope I either get the question mark or a blank black bar.
    Sep 2003
    Utah
    4,327
    And I have 7.5.5. Pro version. On a PC.
    Melbourne
    5,262
    I had a look and found this:
    http://discussions.apple.com/thread....862684�
    You aren't using the XP 64bit version are you, looks like QT might not work well with XP 64bit.
    Ps....I'm running XP 32bit.
    Kuzey
    Sep 2003
    Utah
    4,327
    Yes I am actually. That kind of makes sense. I'll try it on my laptop when I get home from work and see how that goes. Thanks.
    Working Monkey StereoMike's Avatar
    Luebeck, Germany
    1,931
    QT doesn't work right on xp x64. But if you encode them on your machine with LW as qtvr, a 32bit qt installation can play it.
    So x64 can encode it but can't read it's own qtvr files. There's a tutorial in the lw manual that shows what you have to do (in short, parent the cam to a tilt and to a heading null, then apply a stepped keyframe for each one, finally set each channel to offset repeat).
    mike
    If you are not paying for it, you’re not the customer; you’re the product being sold.
