Thread: tga sequence import! refresh my memory
    Always Learning
    Tucson, AZ
    88
    Hi folks,
    I seem to recall a thread about this but cannot find it!
    I have two customers and myself that can no longer import targa sequences into speedit-vt v5.2b(080923) build.
    We do hold alt + first frame as before and does not work for us anymore.
    Please Help!
    Ken
    PC specs:
    LW9.6 (32 & 64 bit) Win 7 Ultimate (64bit)
    Intel Core 2 Quad Q9400 2.66Ghz
    8GB DDR3 RAM
    nVidia GeForce GTS 240 2GB dedicated RAM
    VT5 USER Rich Deustachio's Avatar
    Mount Laurel, NJ
    1,371
    Try to drag in the first frame without holding alt. Hmmm looking at the other threads, holding alt is supposed to work as long as you hold it in until the sequence loads. I will try mine but I am not on 5.2.
    Dynamic Video Productions
    Mount Laurel NJ
    Jul 2004
    Palm Bay, FL
    1,773
    Make sure you're holding down alt before you click on the first image in the sequence to grab it.
    Also, it will only work if your sequence is named filename0001.tga, filename0002.tga, etc. If the frame numbers are anywhere but right before the dot, SE usually won't recognize it as a sequence.
    If you still run into a glitch, the alternative is to set your default still length to 1 frame in prefs, then just drag the whole folder of stills onto the timeline, where it will be treated as a subproject. If you need to do things to it that subprojects can't handle (use alpha, tweak colors, etc.) then you can render it out as a video clip and edit with that. This method works with other still formats, not just .tga.
    Always Learning
    Tucson, AZ
    88
    Thanks for the replies!
    Well after I posted I went back and several more tries I found that I was not waiting long enoungh for the complete sequence to load.
    I than saw this reconfirmed by you folks.
    Thanks again!
    Also it worked okay with SpeedEdit v1.5.5 as well!
    I had to wait, One or two seconds after it looked like it the sequence was fully loaded.
    Ken
