Thread: Faking relief and the DP node kit. (bump to normal)
    May the sauce be with you starbase1's Avatar
    London, UK
    5,571
    As mentioned in a different thread, I am trying to make a lazy way to map tileable square images onto a sphere, to make quick and dirty planets / moons.
    And it's coming along quite well - see the attached image. Now this just uses the diffuse channel, which is why it looks flat - I am mapping the 'equator' with a cylindrical mapping, 2x repeated, and use planar mapping on the poles, masked by a fuzzy disk. (Node map attached).
    Now I want to add some bump, or even better normal, to give it some relief. I'm using the DP Kit, bump to normal, but the results are very odd, and affect which areas are lit without appearing to add any relief effects.
    Now there's a forced conversion in there, which may be a bad idea, but I'm not sure of a better way to do it. Any suggestions?
    Any alternatives?
    Nick
ID:	67424   Click image for larger version.
ID:	67425   Click image for larger version.
    Faith is the opposite of Intelligence.
    Touched by his noodley appendage!
    My Lightwave Graphics & Downloads!!!
    That node only converts bump to normals. You're not starting with bump - you ought to feed the color into DPont's Scalar Bump node first (and you'll get more accurate results by changing it to 6-way sampling in its options.)
    8x2.8 Mac Pro, 8 GB RAM, Radeon 2600XT, Mac OS X 10.5.6 (previously: G5 Quad)
    Caution: tech-savvy artist in full-on geek mode. May obsess over technical challenges until solved.
    London, UK
    5,571
    Quote Originally Posted by weepul View Post
    That's done the trick!
    Thanks!
    Nick
