Thread: VT5.2 not playing mov h264 smooth
    Feb 2008
    DK
    6
    After upgrading to VT5.2 all our Mov files (H.264) movies are ot playing smooth. There are plaing 10-12 frames, then pause for a split secong, plays 10-12 frames, the pauses, etc.
    Have re-installed all, incl. Quicktime
    Feb 2009
    Rapidan, VA
    8
    Same Problem
    Same problem here. We have hundreds of quicktime videos (h.264) that used to play fine, now they don't play smooth at all after the 5.2 update.
    Please help!!!
    Feb 2009
    Rapidan, VA
    8
    Single Threaded Decode?
    I noticed on our system, which has 4 cores, that while the quicktime movie is playing (jerky) the total CPU usage is steady at around 25%.
    I opened up the task manager and set the processor affinity for VT5 to single CPU. Sure enough, that core's CPU usage was 100%.
    So VT5 is doing something in the QuickTime decode process in a single thread, and that task is slow enough to peg the CPU.
    I notice that when I play the SAME video in QuickTime player, the cpu usage is very low, under 5%.
    So what is VT5 doing?
    VT5 USER Rich Deustachio's Avatar
    Mount Laurel, NJ
    1,371
    Here is another thread about this same problem.
    http://www.newtek.com/forums/showthr...=quicktime+5.2
    Dynamic Video Productions
    Mount Laurel NJ
