Results 46 to 60 of 62
Thread: BDD Player node
  1. #46
    da what? daforum's Avatar
    May 2006
    Bristol, England
    1,671
    Thanks for all your help in solving this.
    I managed to MDD scan the HardFX scene and save an mdd file, then play the mdd file using your mdd pointer node. Worked very well as a solution.
  2. #47
    May 2006
    France
    3,965
    Note that even HardFX can't load this kind
    of bdd file, if it lost its original settings,
    at least it needs to be set to '1Piece' mode,
    to not get the same kind of error message,
    ...mismatch number of part.
    In another side '1Piece' bdd file could be applied
    with HardFX (same mode) to a different object,
    it doesn't rely to the object geometry.
    Denis.
  3. #48
    it's funny how i always have fun watching the new nodes...
    you're the champ Denis
    supercool
  4. #49
    May 2006
    France
    3,965
    A Part Move setup sample for linking parts of an object
    to particles, emitter is set to object-vertices mode
    attached to a special object, a cloud of points matching
    centers of parts. Added a Collision floor.
    Animation,
    Node tree, Nearest Point and Particle Info
    set to cloud-of-points/emitter,
    Scene (calculate Dynamics for accuracy),
    Part_Particles_scene.zip
    A Modeler Lscript for creating the cloud of points layer
    from an object layer with parts (slow),
    center_part.zip
    Denis.
  5. #50
    Lightwave junkie stevecullum's Avatar
    Jun 2005
    Reading UK
    3,136
    Really cool Denis!
    i7 X3930/32GB/Quadro 4000
  6. #51
    Super Member omichon's Avatar
    Bordeaux, FR
    716
    Nice feature, thanks Denis !
    But, I tried to setup some bubbles effect according to your demo scene, but unsuccessfully at the moment
    The idea is the allocate each little sphere (as part) of an object to a particle location. The problem is that it is not accurate a the moment and the bubbles are popping randomly (maybe because they all share the same location in the initial object ?)
    Any idea ?
  7. #52
    May 2006
    France
    3,965
    For this case you should use Index output of Part Info node
    instead of Nearest Point node, but since you displaced the
    bubble shape, you will need to add an offset with a Constant
    Vector to match accurately the particle position.
    Denis.
  8. #53
    Bordeaux, FR
    716
    Denis.
    Works like a charm (without adding any offset, btw) ! Thanks again for your help
    As a side note, it appears that PartInfo node is listed in DPkit/Displacement menu, don't you think that DPkit/ItemInfo would be a more logical place for it ?
  9. #54
    May 2006
    France
    3,965
    Yes, logical in term, may be not for using it,
    this node belongs to this list, because, as said in the doc,
    this node ouputs correctly the index, only if it is
    connected to Part Move or PolyMove nodes,
    so you need always to have Part Info -> Part Move
    or Part Info -> Poly Move.
    This can work outside the 'Displacement Node Editor' context,
    for colouring surface with part index as shown somewhere
    in this thread, but using (well named?) Displacement nodes.
    Surely not perfect.
    Denis.
  10. #55
    Bordeaux, FR
    716
    Well, that makes -perfect- sense to me, finally. Thanks for the clarification.
    I should read the docs more carefully
  11. #56
    May 2006
    France
    3,965
    Parts moving along a Null path before returning to their original position,
    Animation,
    Node tree (DP Kit), Part Move, Part Info, TimeLag, Item Info nodes,
    Scene,
    serpentin.zip
    Denis.
  12. #57
    now that's sweet...
  13. #58
    May 2006
    France
    3,965
    I got a report about a crash which happened
    in BDD Player node, with object containing single points
    (not belonging to poly),
    BDD Player node is working now with these points,
    each single point is treated as part (conforming
    BDD Player behavior to HardFX).
    Not necessary usefull, but at least doesn't crash anymore.
    Part Move node is compatible with single points too,
    with a Z+ default normal.
    BDD Player displacement plugin has been updated too.
    DP Kit & BDD Player x32 versions available for download.
    Denis.
  14. #59
    May 2006
    France
    3,965
    Fixed by Marvin in x64 BDD Player displacement,
    http://pagesperso-orange.fr/dpont/pl...tml#BDD_Player
    And x64 DP Kit, BDD Player node,
    http://pagesperso-orange.fr/dpont/pl...l_Nodes_2.html
    Denis.
  15. #60
    Hi Denis, awesome job, love the Shifter plugin for many situations, but is it possible to have it travel from point A to B deforming alonga path. Some great guy ,bryphi77, did a tutorial with your plugins:
    http://www.youtube.com/watch?v=_WV7A...d&noredirect=1
    but if i want to travel like in this videos, how this can be done, i'm just starting to understand your plugins, thanx a lot:
    http://www.youtube.com/watch?v=AFVKBrxpans&noredirect=1
    check out the ribbons. thanx again.
