Thread: hub crashes on startup
    I have seen this posted before but couldn't see a solution. Under 64-bit lw9.5 the hub crashes instantly on startup. If I run the 32bit hub no problems but 64-bit crashes... has anybody else seen this?
    Registered User Gary Heck's Avatar
    Sep 2003
    Claude
    87
    I had this happen on 32 bit. It was a firewall problem.
    Netherlands
    5,560
    Did you try deleting your config files?
