Results 1 to 15 of 15
Thread: Unwrap2?
    houston
    96
    Unwrap2?
    Can anyine walk me through using unwrap2? I tried it and can't do a thing w/it. I'd use unwrap, but it only runs under OS 9 and I refuse to use classic, why drive a Pinto when there is a Ferrari in the garage?
    Create an image mapped surface in either Modeler or Layout. In Layout navigate to generics:unwrap and launch unwrap. In the unwrap panel select the image-mapped surface you want to unwrap and save it out with your chosen file type.
    I think the only slightly counter-intuitive thing about the process is that you need a 'dummy' image map already applied before unwrap will work on the surface.
    Julian
    The Mac Lightwave Resource Page
    http://www.exch.demon.co.uk
    Brain dead, but here...
    Vancouver, BC
    843
    Using a dummy images doesn't work for me...
    I'm using a dummy image for Unwrap2 and it isn't working... go figure . Any other ideas?
    Arlen
    Cheers!
    Arlen
    Fabmedia Studios
    print, interactive, & motion media design
    My Blog
    Using dummy images works for me...
    Hi Arlen,
    Dunno what's up. Where exactly in the process is it failing? Here's what I'm getting:
    Julian
    Vancouver, BC
    843
    everything is fine but....
    I don't get the black and white output or anything else. It builds a file with nothing except the background.
    A
    Cheers!
    Arlen
    Fabmedia Studios
    My Blog
    Checked that you're in Object edit mode in Layout? IIRC the other edit modes will cause it to produce a blank image...
    Regards,
    Terry
    Vancouver, BC
    843
    object edit mode?
    what do you mean? having Modeler and Lightwave synced?
    A
    Cheers!
    Arlen
    Fabmedia Studios
    My Blog
    Sorry, I just checked my facts and it appears that I was talking out of my ars*
    I've definatly had the blank image problem, I'd thought it was due to not having Objects mode selected in Layout (lower left corner), but it seems that Unwrap doesn't even start if you don't have a textured object selected, so that wasn't the problem. Sorry. I assume you have the latest version from here?
    http://mywebpages.comcast.net/erniew/getstuff.html
    Regards,
    Terry
    Vancouver, BC
    843
    the latest and greatest...
    Yes actually. I had downloaded it yesterday and yet, no luck. I'm selecting the image and have tried entering a new image size and even working with the existing image size, using the image as a background and not. There must be something I'm not doing right. What a week. I figured that i would try to start using UV mapping, which from what I understand and realize that it's extremely powerful. It's just getting something out so I can use it. The screen capture of the UV map hasn't worked yet either. The image is out in compared to the mesh.
    I must be stoopid or have lost my f****n marbles.
    Arlen
    Cheers!
    Arlen
    Fabmedia Studios
    My Blog
    San Diego (kind of)
    69
    I tried downloading this and layout won't load the plug-in. Is there another source for this?
    Thank you
    Vancouver, BC
    843
    A solution for me
    Ah hah! I've found a potential problem. I turned off the Hub. And presto, it works just fine. I deleted the plug-in and then reloaded it. It worked for me and Lightwave is much more stable for me under OS X (10.2.4).
    Woo hoo!
    Arlen
    Cheers!
    Arlen
    Fabmedia Studios
    My Blog
    San Diego (kind of)
    69
    cant load plug-in
    Anyone else have the problem of layout not loading this plug-in?
    I'm on a PowerBook G4 running 10.2.4. I've tried the download from the link on this thread but no luck. Other plugs I've got so far seem to be okay.
    This sounds like a cool tool to use.
    Thanks for any help.
    San Diego (kind of)
    69
    found the problem?
    I downloaded the .zip file on my other (sys 9)computer and now it looks like a plug-in. Hope it works....gotta stop answering my own questions
    San Diego (kind of)
    69
    test post
    test, test
    Spruce Head, Maine
    16
    Unwrap.p and SubD Surfaces
    What's the trick to using Unwrap.p with SubD surfaces? Are there any tutorials on this subject? Thanks all...
