Thread: qttools plugin not in 9.5?
    May 2008
    Iowa
    39
    Is anyone else missing the QuickTime plugins for 9.5 windows? I am on a windows XP 64 PC. I tried the Newtek Technical support but they where unable to help. (She had the plugin on her LW 9.5 32 bt PC but could not tell me if it was available on the 64 bit PC) The plugin is present on my Mac UB 9.5 beta. I tried the one from 9.3. Will not load. Help me Obi Wan
    Traitor
    Perth, Australia
    453
    quicktime is not available for 64-bit machines.
    Talk to Apple, not NT
    May 2008
    Iowa
    39
    Thanks. for the quick responce. Is there a reason the regular Quicktime program works fine on my 64 bit machine but a Quicktime plugin is unavalable? Just wondering.
    Stuttgart, Germany
    13,543
    Quote Originally Posted by hansen View Post
    Yes, the regular quicktime that is running is the 32-bit version. Which is the only one that Apple provides.
    It would need to be 64-bit to be used from a 64-bit application - you can't mix and match 32-bit and 64-bit binaries.
    Cheers,
    Mike
    Dec 2003
    Portugal
    1,819
    you probably already noticed too the problems with quicktime in browsers like firefox...it has lots of problems in 64 bits
    Airwolf 3D man virtualcomposer's Avatar
    Jul 2008
    Castle Rock, CO
    1,440
    I believe you can render out to PNG files, put it in Final Cut or what ever program you're using to edit and export into QT 32 bit. Can anyone correct me if I'm wrong? Something's got to animate it.
    Graphic Designer & 3D Textures
    -Mac Pro 2.26GHz | 8-core | 3TB HD | 12GB RAM | Dell Ultrasharp 2707 | ATI Radeon HD 5770
